Return to home
mb-1953
What does it mean when the new 2.6.2 release states" IMPORTANT: Please set Return to Home and GeoFence positions for Bank 1 and Ban 2 (if used)? I use my transmitter to set "Return to Home", and the heli is always in bank 0. Does this mean that when I switch to Bank 1 and/or Bank2 that Home position is not known or has to be reset?
It mean that after the last update you have to set Return to Home and GeoFence for Bank 1 and 2 again. Otherwise it would be unconfigured for these banks.
mb-1953
I am confused. I can only set return to home in bank 0. When I switch over to bank 1 or 2, there is no access to the channels tab. How do you set return to home for banks 1 or 2 without using the channels tab?
There is no access, but the settings are still the same for each bank. Because channels and some other parameters are common for all the banks. These parameters are greyed in other banks and can be configured just for Bank 0.
