[SOLVED] 4dsviewer
FrankFuss
Hi Tomáš, will there be an update to the 4dsviewer for the latest firmware version 2.7.1? I know you have other higher priorities. Keep up the good work.
it will be updated as always. There is no reason to not update it :)
Genesis
Hi Tomas,
Is there a new link for profile viewer as the link in the settings tab does not work with 2.7.1 profiles, only 2.6.4 and older. Thanks in advance.
Best regards,
Kevin
Genesis
Tomas,
When can we expect a new viewer update to be available?
Best regards,
Kevin
jjuk
+1
Just setting up a heli and would like to use the viewer for 2.7.1
Genesis
Still no updated viewer :(
it should already work.
jjuk
It doesn't for 2.7.1 last time I tried it.
You can try again :)
FrankFuss
It looks like "Stabi -> Rescue collective pitch" is not being displayed correctly for a 2.7.1 4DS file.
