Telemetry data for actual and set opening are missing
Serenus
Following setup:
- Spirit pro with integration cable
- YGE 95LVT
- Jumper t16 (OpenTX)
- R-XSR receiver
The telemetrie cable from the YGE 95LVT is connected to the telemetrie port of the Spirit pro (without the red cable).
The Spirit Pro is connected with the integration cable from to the R-XSR.
I get the Spirit settings on my Jumper t16 and some telemetry values from the YGE.
I am missing the values for actual opening in % and set opening in % (Regleröffnung).
Do I have to configure these values manually? All other values could be found automatically.
On another Heli I have connected the YGE with Texy to the R-XSR (not over the Spirit) and the values for actual and set opening are available.
Thanks in advance for your help ;-)
Best Regards
Serenus
Serenus
is there no way to get the values? If not it would be good if you can let me know.
Thanks.
Best Regards
Bastian
this is displayed as 5120 telemetry variable.
Range is in microseconds, so you can see this value in range of Throttle Range Min./Max.
So it is only different interpretation of throttle %, more precise.
Serenus
Hi Tomas,
I have checked this value (5120). This is the value which I set. I am looking for the actual value of the ESC to see how often the ECS will be at the limit.
When I am using the telemetrie from the ESC directly to the receiver I am getting this value.
Best Regards
Bastian
