Spm6210t & ix12 and spirit 2
Neilsteers
Looking for help, have the 6210t connected to the spirit by JETI cable red and brown rudder and orange to pit, esc to aux1 , if I connect servos to rx they respond but connected to the spirit 2 they don’t and in both scenarios the bars do no move in the channel screen in the spirit wizard, what am I doing wrong ?
10x
I assume you mean the 6610t?. Have you set receiver type to SRXL2 in the Spirit in the general tab, then in rx....
Neilsteers
Hi
Yes the 6610t, and yes set to srxl2
HeliMLM
Neilsteers wrote:.....and orange to pit...?
if you have really connected to PIT (middle pin) this is the problem... check wiring with Spirit manual: should be the topmost pin iirc.
cheers
Michael
Neilsteers
Hi Michael no the orange wire is in the top pin
HeliMLM
Ok... would have been an easy one :)
and the firmware on 6610T is updated and Spirit is using actual firmware?
cheers
Michael
Neilsteers
I have updated the rx but not the spirit software, software on wizard is showing latest release 2.8
