Servo wiring and BT module
Nitro Head
I am fitting the spirit to an Align Heli, their naming convention is.
Elev servo at rear
Pitch on left front
Ail on right front
Is this the same definition as your manual for aileron/pitch servo? Does the spirit actually care about which is the ail or pitch servo?
Also I am connecting the Bluetooth module to the Spirit can I use this with the windows software or is it only for the Android software?
Thanks,
for Spirit, it is:
CH1 - Aileron
CH2 - Elevator
CH3 - Pitch
But in Spirit, you can even swap Aileron/Pitch to achieve minimum reversing - so it can be little bit easier in initial settings.
If you have some troubles you can ask me anytime.
Nitro Head
Thanks for the reply it good to know that the spirit allows swap of the pit and aileron.
Regarding the BT module does this work ok with the windows software?
Thanks.
It is supposed for Android only at the moment. But there are some people that are running Windows app successfully yet it is not recommended.
