Spektrum Airware 2.06 - no more integration
fassla
There is no more "TextGen" in Telemetry settings!
Therefore Spirit integration on Spektrum receivers is no more available the moment you update to this new firmware
Kluftinger
Spektrum™ AirWare™ Change Log 2.06:
• Removed “TextGen” as an option on the Telemetry devices list.
If TextGen is being provided by your Flight Controller or ESC, it will appear automatically on the list of roller screens, making configuration simpler.
Otherwise, it will automatically be hidden.
HeliMLM
... seems to be a problem on Airware side. there are reports of the same happening with Brain too. TextGen not working, alarms not working, telemetry not being recognized correctly... etc :(
nb: ... i just saw - the report for Brain and the answer of MSH support was from fassla too :)
cheers
Michael
10x
Now been sorted with version 2.07
2020-Sep-11
Version 2.07
Corrections & Improvements
• Corrected a bug that was only present in version 2.06. This bug could cause gyro
correction direction issues when using Forward Programming devices.
• Corrected issue when using TextGen devices that would not populate on main
telemetry screens.
• Restored ten Flight Modes in Sailplane Model Type.
• Eliminated inconsistencies in Heli mode when Governor or Gyro is partially
configured when model is saved.
Audio System Changes (Voice output models only)
• For all languages please use Sound version 1.09 (2016-Oct-12)
• If you previously updated to Sound 1.09 there is no need to update again.
Hello everybody !
I think Spektrum reacts quite fast of that problem, that sounds good -
But this airware is in beta status, I will wait till this beta status is over and we have a none beta status -
Best Regards
Matthias
HeliMLM
...as of news i've seen in other forums the problem seems still NOT to be solved in Airware 2.07.02... at least not for one big other FBL supplier their tests have failed. so maybe someone can confirm for all the Spektrum users if it is really solved for Spirit units?
cheers
Michael
10x
Just tried it on spektrum all ways and can not get textgen to work. All the other telementry works fine....I perfer to use tablet or pc so not a
problem for me...
10x
Spektrum has released 2.07.03 now and i can confirm that the textgen menu now works...
