[SOLVED] Stabi normal
latjo-k
Hi
Somting strange happens,when i activate stabi normal at the beginning of flight (hoover tail in)
the heli will go to the right,after 5min of normal flight i hoover tail i again and activate stabi normal,
the heli will go to the left??
I have the box stabi correction and signal processing extended ticked.
If i untick the boxes stabi normal works correct.Rescue works as it should if boxes are ticked or not.
On the bench the swashplate act exactley as it should when i activate stabi normal and rescue.
perhaps Tomas have an idea what it can depend on?
I have done all setup by the book (manual),unit Spirit RS.
The vibes are under 35 in all axis,in Jeti graf under 20.
Bank 0 stabi normal 1600rpm
Bank 1 Rescue normal 1900rpm
Bank 2 Rescue normal 2100rpm
Othervice the unit works exellent
//Latjo
please tick one or another.
When both are ticked it has no improvement.
Stabi Correction ON and Extended Signal Processing OFF should give you the most precise results.
Or you can leave just default settings.
Please check this page:
latjo-k
ZeXx86 wrote:Hi,
Hi
I ticked only the extended signal processing box,stabi works perfect.
Thanks Tomas and Spirit team
//Latjo
