[SOLVED] Spirit RS - which Kontronik Telemetry cable to use?
enied
a friend of mine decided to migrate his Diabolo 800+ from Neo to Spirit.
Components used:
Jeti transmitter DS-24 (FW 5.05)
Spirit RS (FW 3.2.1)
Geolink (FW 1.2.1)
Kontronik Kosmik 200 HV ESC
Now he is working on the ESC telemetry.
My question: which cable must be used to connect the Spirit RS with the ESC and how should he plug it in ? The documentation of the Spirit RS is not very clear to us in this topic.
Thank you in advance for your reply.
Best Regards,
Eugen
buttles
Hi, you need this....https://store.spirit-system.com/en/acce ... cable.html You may already have the connectors to make a cable?
The Telemetry guide shows the settings in the Spirit and the ESC. Assuming you have a Prog Unit to talk to the ESC??
Tomas says the Spirit TelMe will eventually have all the available parameters from the ESC in due course.
Till
This is the best way for the RS, you could connect the telemtry to the side Port Sat 1 an have the others free to conect the master and slave an a buffer.
enied
Yesterday we got it to work. Many thanks to buttles and Till for their valueable information.
Best Regards,
Eugen
