Tail Servo doesn´t work corrrect
Voodoo2
Hallo,
today I try to adjust my sprit. The tail servo (rudder) is on CH4. The diagnotic shows me +-118% but if I move the stick the servo makes only 4mm way.
I tested a other channal an the servo makes the hole way. Its a BLS954. Frequenz is 1520 and 333.
Does anyone have an idea?
Regards Jens
Try to set Head Lock mode, your gyro is most probably in Normal/Rate mode.
You can just set Gyro gain so the diagnostics will show HL instead of N.
Voodoo2
Ok I raise the gain and the servo starts work correctly :D
Now I have the problem that CH4 is not CH4 in my Radio control. I used a DS16 with Jeti Rsat.
The servo display show me the channels for example CH3 Pitch. If I change CH3 in the Spirit Sotware to Pitch it doesnt work. :?
Great.
This is not a problem. Channel numbering is different between each transmitter/receiver.
It should work with defaults settings.
