updated my Radio DS 16 and Spirit RS to 3.2.2.
If i use now the device explorer to RS the screen jumps allways back after
a couple of seconds to the device explorer.
What is wrong ?
Best
Manfred
Update 3.2.2
can you check if serial number of the unit ends with -a1 in the Connection tab, Spirit Settings?
Also have you updated BIN file in the Devices directory (radio)?
Great. Is something connected in the E2 port of the Spirit RS unit?
It seems connection is somehow unstable. By connecting something in the E2 it can cause such troubles, because E2 is used for data transmission in normal configuration.
Thank you.
Could you please share your settings?
Preferably 4ds file. Tomorrow we can verify behavior with the settings and let you know. I believe it can be resolved easily. But we never encountered such behavior.
Thank you. We have not found anything strange in the settings. It is working perfectly with our untis.
Maybe you have opened Spirit Settings at the same time as the integration? If you will access Spectrum Analysis there then it will close the integration. This is correct behavior.
