Return to home
Bill-kraken-700
Hi there the manual and software seems to contradict each other when return to home on 4 is enabled the manual states it returns to take of position and in the software it states return to power on position. Can anyone verify which is correct?
Bill-kraken-700
Surely some one knows the answer?
there are several modes for Return to Home.
4th function will return model to take off position and is special case of RTH. While the rest will return it to programmed Home point.
Bill-kraken-700
ZeXx86 wrote:Hello,
So if I power the heli up on the bench then move it to the take off point it will return to that point it toke if and not over the bench where it was powered up ?
Yes, that is correct. But 4th RTH mode must be engaged, not other.
You can try it easily in the flight in a high altitude.
Bill-kraken-700
ZeXx86 wrote:Yes, that is correct. But 4th RTH mode must be engaged, not other.
Many thanks for your support. One last thing. I read you helped another customer reset the gyro to fix manufacturing process. Can you tell me how I do this ?
this process should be done only in case you have some problem and there is no other solution.
Have you encountered something similar?
Bill-kraken-700
ZeXx86 wrote:Hello,
No not yet. I haven’t test flown yet.
Bill-kraken-700
ZeXx86 wrote:Hello,
the compass calibration was performed in doors when installing the units should i do this outdoor or will this not matter
cracked canopy
Bill-kraken-700 wrote:
ZeXx86 wrote:Hello,
Its always best to perform compass calibration out doors in an open area.
