Hi
After a innumerable amount of lockouts and many many recievers and transmitters later I have figured out there is so much brutal noise on 2.4gz where I fly that I have tried a jumper t18 with frsky R9 Support on 868mhz. It works great.
I figured that since the R9 system uses S.port, everything would work with my spirit units.
Anyways. No lockout yet. Telemetry works beautifully. Fuel, Esc data the works.
But somehow the opentx integration scripts does not work with R9.
Everything on the test helictopter should be right. If I just swap the receiver to a frsky 2.4ghz
Everything works. sbus, s.port telemetry, and integration scripts.
Switch back to R9 reciever: sbus, , s.port telemetry, but integration scripts does not work.
Data fields and progressbar remains empty.
I love the integration scripts and use them ALOT
Would be great if I can get it to work somehow
