New Geolink Sensor GPS has sometimes lat and lon reversed
Storchy
I wanted to calculate the distance between the pilot and the helicopter and looked at the table of the GPS sensor.
the variables are pilot-lat / pilot-lon and lat / lon for the helicopter
The calculation only works every other time or so.
I researched and found that sometimes lon and lat are swapped and then until the geolink is turned off
Thomas, you can take a look at that
No problem, if I find that now I just turn the two values around in the lua script
Ciao
Jörg
Storchy
Now i have seen that the pilot coordinate are reversed sometimes
Just have a look, no problem
Ciao
Jörg
Storchy
Here is a screenshoot, but i live in Germany :D
databeer
Do have the same problem. Latitude datas are saved under LON and Longitude datas under LAT on the Jeti Logfile. Thomas, could you correct it? Thanks
