No more log results ?
Carthago
at what point in time is the recording in the log file actually started?
At the moment I only ever get "Duration 0" from logviewer, no matter how long the Spirit was powered on.
Nothing is entered for "Previous", i.e. no problems or no recording at the previous start.
The transmission of the telemetry data to the transmitter works.
Regards,
Toni
there are 3 flight logs that Spirit unit can have.
1. Spirit unit has event log that is recorded from the very beginning when unit is powered on, until power is turned off.
The log is not saved to a memory until some bigger issue will happen. So normally no log from "previous flight" should be recorded.
2. Spirit GT and Spirit GTR have both RealTime Log as well. This is much more detailed log that can record everything each 20ms. For example channel movement, helicopter movement, acceleration, position and many other.
This is recorded as soon as the model will start the motor with blades on and will stop when blades will stop.
3. When GeoLink is connected then flight log from GeoLink can be obtained. All GeoLink related variables are logged there. It is started in the same way as in point 2.
Carthago
Hello Tomáš,
thank you for your detailed explanation.
I have a Spirit Pro and so far I have always been able to view a log with the logviewer after landing, which continuously records things like "Good Health Message" or "Governor engaged". But now it is always empty and shows "Duration 0".
Thanks and best regards,
Toni
