Anyone in support know the answer?
Why doesn't my helicopter leave the ground.
Lifts off fine in normal mode with these settings off!
Michael
Can Position and Altitude Hold be engaged on the ground?
MichaelT1960
Someone finally answered my question!!!
Thank you!!!
Michael
Thank you!!!
Michael
Simple answer - it is not recommended, especially not altitude hold. Because it will hold altitude and you will be unable to lift off...Can Position and Altitude Hold be engaged on the ground?
MichaelT1960
Doesn't it matter what mode of altitude hold is selected (1 or 2)?ZeXx86 wrote:Simple answer - it is not recommended, especially not altitude hold. Because it will hold altitude and you will be unable to lift off...Can Position and Altitude Hold be engaged on the ground?
In the manual it says that one allows collective pitch changes and the other does not!
Michael
