[SOLVED] BEC slave and Telemetry cable with an Y-cable to E1
Manni
is it possible to connect the BEC slave cable and the telemetry cable of a Kontronik Kolibri 140 with an Y-cable with the E1 port of a Spirit RS?
If yes, I could use the switchable AUX port for the PowerBackup.
Greetings Manni
yes, it can be used in this way. Slave cable from BEC is not sending any signal normally, but it depends on your ESC. If there is no signal wire from secondary BEC then it will work for sure.
