Tail gyro working in wrong direction.
a20cae
Hi All getting really frustrated with these system bought 3 u spirits and 1 spirit 2
Not getting anywhere.
Symptoms.....
Align 450 spirit 2, in frame pins at the back and led and labels pointing towards the rotor head.
When you lean the heli over the cyclic leans in to the center both fore and aft and left right correct I think.
The tailslider moves in the opposite direction to rudder stick movement from behind heli also correct.
The bit that does not work is the tail gyro direction is wrong, it just looses control and spins round.
I have played around with the orientation position settings for the unit which sorts out the tail giro direction I can hold on the pad but at least one axis on the swash leans in the wrong direction.
Can find a setting in the software just to reverse the direction on the tail gyro only.
Whats the test to check its in the frame the correct way, and whats the fix.
Chris
hi, the system works fine if you set it up correctly according to the manual:
https://manual.spirit-system.com/index. ... =Main_Page
or videos can help:
https://www.youtube.com/watch?v=oVXWHO5RH74&t=1052s
Please make sure to use the Setup Wizard.
It is VERY important to set all parameters according instructions.
For example If you try to set model just that servos are moving well but you will set for example Mounting Position not how it is in reality you it will never work correctly.
For Tail to work in correct direction you only have to:
1. Set Mounting Position of the unit - According your description it is Horizontal (180°). Any photo would help a lot.
2. Set Servo Reverse in the Servos tab.
3. Set Channel Reverse in the radio so that in the Diagnostic tab channel bar movement direction correspond to your stick.
Nothing else is needed.
