Unable to compass calibrate
raceboy1
Getting real frustrated with this system, I’m switched this Heli from an Ikon
I have it all set up, but I can not get thru the Compass Calibration
The Firmware was flashed to Current
Here’s the process that I did
S elected set level Tab
Selected the Calibration Tab
Powered down the heli
Went outside
Repowered up the Heli with the transmitter
And at that point I get a solid Greed light on the GeoLink
The manual says I should get a rapid flashing Blue light
This never happens
So what is going on
10x
Have you tried going out side without powering down the heli? Just a thought...
rapid blue flashing on the GeoLink should be there only when moving with module.
In any case if you will power on the GeoLink for 3 times without successful callibration it will return back to previous calibration.
Then you have to click at the Calibration Request button again.
