Gyro Mode Switching
Mrhelicop
I have spirit gt (latest firmware) on 2 align trex models, I am using radiomaster/edge tx, same radio model settings on both. All works accept the gyro mode on channel 5 which will not switch from heading lock to normal mode on one of the models but works fine on the other one. The dia page shows -100 to +100 working on both models. Any ideas?
Normal (Rate) mode is available only when Stabi - Function is set to Disabled or when it is set to Stabilisation (Scale). This could be reason why it does not work for you.
Mrhelicop
ZeXx86 wrote:Hello,
Many thanks, that was the problem, all sorted now.
