Stick comand
john1127
Whats the difference in Stick priority and Direction control rate for control of heli in stability mode flying thks.
In the stabilization mode, you can change Direction Control Rate which is changing how much you can control the helicopter.
With high values you can change the angle a lot.
john1127
What does stick priority do then.
With stick priority you are directly control the swashplate.
Direction Control Rate determine only rate of allowed change.
