I've got a 450L dominator with 460mx 1800kv (6s) motor.
I'm using YEP 90LV ESC which has an rpm output.
In the Gov setup menu, i cant get accurate current rpm. The motor has 6 magnets, but 9 stator arms. How many is the pole count? if i set 3 to spirit, i get 3200rpm current rpm above 50% throttle. if i set 4, i get maybe correct rpm read at lower throttle, with 5 divider i get better readings at high throttle. but non of this is correect.
The gear ratio is correct, 11:1. 11t pinion, 121t main gear.
it seems it would be good if i can set a 4.5 pole divider. I'm stuck now, please help
Here you can find pictures about the inside of the 460MX motor:
http://www.helifreak.com/showthread.php?t=636351
thanks.
