Scale setup
mkgy
Question:
Recommended setup the 700 size, 5 blade scale heli?
Thank you for your reply.
mkgy
No 3D, smooth scale flight.
You should set Flight Style to 8, Cyclic Feed forward to 3-4. Rotation rates could be 8 or less and TX expos 25-40%.
More problematic is mostly rudder if there is heavy fuselage so more tunning may be needed then.
mkgy
Thanks. I will report on the developments.
mkgy
Video:
0:46 sec: This is what could be?
3:08 sec: Rudder discontinuous.
LOG VIEWER: no error
Otherwise a very good Spirit FBL system.
Thank you in advance for your response.
mkgy
Currently, using these settings:
Delete...
Thank you very much for the photos.
You can save your profile in one file and send it here, so you do not have to take these shots at all.
It could be caused by heavy tail. In this case you may try to increase Piro Consistency even more or to set Revomix which should compensate it well.
For scale helicopters revomix is required probably in all cases. Maybe 3 points could be enough.
mkgy
Getting better. Thank you very much for your help.
Probably it will be a good setup:
700-800scale.4ds
(255 Bytes) Downloaded 256 times
Thanks for your setup, it is OK.
mkgy
So now flying in stormy winds with Spirit system :) :
