[SOLVED] problems update
marcelo
good morning. I have a problem. today I maked a download spirit 1.3.1, then when I flash this firmware into spirit the light goes off e the unit not working at all.can you help me?
please check this thread with solution of your problem:
http://www.spirit-system.com/phpBB3/vie ... f=20&t=973
I think that you can see version 1.2.0 because it is in cache of your browser. After pressing F5 it will load correct page.
marcelo
good morning sir Zexx.my not show any light at all.
but when the flash is done, the program tell me to turn off e on to work , but is not working.
I tried to flash , but is not working, can see only : disconnected .
Ok, thank you for the info.
In this case I will send you private message with guide that will help you.
marcelo
thanks for your quickly reply. I am waiting for.
marcelo
done. thank you mr Zexx. I love the spirit flybarless and your have the best support ever seen.
You are welcome!
paparomeo
marcelo wrote:good morning. I have a problem. today I maked a download spirit 1.3.1, then when I flash this firmware into spirit the light goes off e the unit not working at all.can you help me?
Good evening,
Mine Spirit also don't want to go after an update.
Not even a short flash of the led when i powered it.
I try the "rescue" procedure but without any good result :(
ZeXx86, I need you :P
Patrick
can you tell me, if you can see blink of the LED when you connect the power?
paparomeo
Hi
No I can't see any blink of the led.
I powered the unit with a 2S lipo.
Without any thing hook on it, only 2S lipo.
Thanks to look at my problem ;)
And sorry for my bad English :P
