Yah thats how I did it. Used subtrim to 90/ level swash (its on a goblin 380) then adjusted push rods so the blades are level when folded together. Then set my collective, cyclic ring and cyclic 6 degrees tuning.
My swash was moving backwards so I had to reverse my pitch channel so currently my rescue pitch is already at -60 and when I checked it 100 it was already at -100.
Few setup questions
I think ZeXx86 is asking you to verify if you have the same absolute value of pitch when you setup and activate -100% Rescue pitch and +100% Rescue pitch. So for example +12 degrees and -12 degrees respectively.
Exactly, and I think ZeXx86 was asking you to check on the other side too and let him know, to help you troubleshoot your problem ))))))Alyon187 wrote:No ive only checked it to the appropriate side that gave me positive pitch
