Gov 1.3.1 Goblin 700 Gasser
Malc1
This is a really good idea and would cut out a lot of the guess work.
Yes, we have implemented it during development of 1.3, but it has to be tested more thoroughly.
Scott H
In all seriousness, if you want a tester, I'll be happy to give feedback. My availability to fly now is on the weekends though.
Scott
Dawiev
Hmmm, mention of the mythical beast again... ;) Pictures of their sensor installations ? Maybe even just pictures of them ? I don't want to quote Victor Meldrew, but ............
Yes, I agree that the Futaba sensor is not positioned as I would've placed it, but it gave me the exact signal strength and it works. Option to select RPM sensor and invert the signal so we can use the Futaba sensor ? Can the system be changed to show signal strength with an Align or other sensor ?
Ps. I appreciate that this is a niche part of an already niche market and things like the Aero makes more business sense. Smile and move on. :)
Scott H: Thank you very much for your offer. Unfortunately there is always some possibility that something will not work correctly so the testing pilot must be prepared for everything. So we do not want to put you in any risk.
But if you feel that it is not a problem, we are glad for any testing, especially with gassers, where the count is very limited.
Malc1
No more testing of the Spirit governor for me for now on my 700 Nitro - I've given up.
I have assigned the throttle to channel 1 of the Jeti receiver and have fitted a Multigov Pro instead that just needs a test flight.
I have another standard unit here ready for a Gaui NX7 build and a Pro unit ready for a JR Vibe electric build.
I may try the governor again with these.
