3D Setup
pabloK
Hi
I recently installed spirit Pro on a TREX 500L and a 600L both dominators.
Flyes great, very smooth both.
But I feel so smooth for 3D, wich parameters do you recomend me to modify in order to have a more responsive/aggresive behaviour?
I am attaching configuratons files
I will appreciate any help, thank you very much
600L spirit pro.4ds
(255 Bytes) Downloaded 133 times
500L_spiritPro_PK.4ds
I recommend to set Sensor/Rotation rate speed to 10 (especially for Cyclic). Now there is value 8, which is default value (good for beginners).
For 3D value 10-11 should be fine.
There are more parameters for making it more agressive, but I think that you want to set rotation speed first, because it is very slow in default.
pabloK
great, I will try diffrent configuration using banks only on this parameter, for cyclic and for rudder
thank you very much
pabloK
works great
thank you
