I am new with Spirit and got my first one for 14 days ago. I have set up my Spirit with the computer and that is quite easely. But when I turn on my Bluetooth there is something wrong. It is pairet with the android phone, but it seems to it cant find the unit. When I power the Bluetooth up there is a blue diode flashing, and when I open the Spirit app in the phone the blue diode got solid. But it ask for the unit and the conecting symbol is not ok. What is wrong ??
Kind regards Henrik
Bluetooth is not conecting.
henrikbach
It looks like cable in the SYS port of the unit is not connected properly OR you are powering BT module from a different power supply (for example battery).
If there is a different power supply, you have to connect grounds together. Then it will work.
henrikbach
I use a seperate battery to power the bluetooth up. I tryed to power the bluetooth up from an extra port on the Spirit unit and NOW it works. Thank you for very fast reply.
Henrik Denmark.
Henrik Denmark.
