I noticed that after I hooked up the bluetooth to both my regular and pro spirits after updated everything all to 2.0.0 that I couldn't make any adjustments to the setup portions such as tail end points and cyclic ring. I am using bank switching and made sure I was in bank 0 when attempting the adjustments. So far those are the only two areas ive noticed but there could be more. Is anyone else having this issue?
Ah ok will do. I remember now hitting that the other day when I couldnt get it to connect but later figured out that it changed the device selected which then connected just fine but didnt unselect the basic mode so im sure thats it. Thanks!
