Here are the vibration plots:
3.000 rpm
best regards Wolfgang
Cyclic gain and helicopter size
and 3.600 rpm
every plot without main blades and with tail blades
Checked the bearings => ok
Checked the main shaft => ok
Checked the spindle shaft => ok
Checked the swash plate => very little axial Play => changed by spare => ok
Lowering the belt tension => more vibes (se next posts)
regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
Thank you very much for the plots.
The biggest spike is coming from the rudder.
Unfortunately when you mount rudder blades, the spike can be a few times bigger and make a huge troubles.
Without blades there shouldn't be nearly any spike.
Can you mount the tail blades and carefully spin the helicopter to check the analysis?
He wrote that the plotes are already with tail blades: "every plot without main blades and with tail blades"ZeXx86 wrote:Thank you very much for the plots.
Correct,
all plots are with tail blades mounted.
Edit: Additionally I can say: Telemetry vibes level in flight was at maximum 12% (normally lower ~7%).
regards Wolfgang
Ah, sorry I have overlooked this.
In this case your plot is looking quite good. At the beginning I can see some low frequency vibration that is pointing that the unit is probably holding not too hard - but this can be caused if helicopter is moving little bit during measurement. If it is mounted with stock tape, then it is OK.
Maybe you can also post your settings so we can check that everything is OK there. But I believe that the problem is somewhere in the rotor head.
If you can observe oscillations on both aileron and elevator axes, then the helicopter is not probably OK. Something must be slightly bent or assymetric.
Maybe the blades are manufactured not too precisely? Normally more expensive blades should be in balance quite perfectly.
Or the last option is bad aileron/pitch servo that is oscillating - if you spoolup helicopter it shouldn't move at all.
The heli moves a little sideways, but only when spooling up on a hard table. When I set It on the service towel there is no movement (when the tail steering rod isn't in place. When It is in place there is some side thrust form the tail rotor in neutral servo position (as recommended by the manufacturer).ZeXx86 wrote:Or the last option is bad aileron/pitch servo that is oscillating - if you spoolup helicopter it shouldn't move at all.
I could try to fix the Spirit harder with a velcro strap. Due to bad weather and work times
My actual Settings are attached. Actually only bank 0 is used until the wobble is fixed.
- Attachments
- OXY3_2016-03-02_2.4ds
- Bank 3
- (255 Bytes) Downloaded 64 times
- OXY3_2016-03-02_1.4ds
- Bank 1
- (255 Bytes) Downloaded 60 times
- OXY3_2016-03-02_0.4ds
- Bank 0
- (255 Bytes) Downloaded 75 times
regards Wolfgang
As mentioned before the mounting is:ZeXx86 wrote: ... At the beginning I can see some low frequency vibration that is pointing that the unit is probably holding not too hard - but this can be caused if helicopter is moving little bit during measurement. If it is mounted with stock tape, then it is OK.
boom mount | stock tape | 3 mm forex sheet | stock tape | Spirit Pro
This is because the frame is a little to narrow for the Sprit Pro. But the wobble was an issue with the microbeast pro too. There was only the stock tape.
Bend parts in the main rotor are rather unlikely, because everything is already changed:
- main hub
- dampeners
- spindle shaft
- blade holders (including bearings)
- blades
- main shaft
- upper bearing block with bearing
regards Wolfgang
