I'm comfused. I have bank 0 stab nor bank1 stab acro and bank3 resque.
At neg pitch res give pos pitch, at flying pitch at 6. resque on ground levels swash but cuts pitch down to about 4.
Is this normal have pitch slider set to 80. Thks, have flown with spirit for months but never had banks turned on yet.DX8 with sat. thks
resque
rescue is working independently of your stick input. So anytime you will activate it, it should give you a positive pitch.
When rescue or a special mode is activated, you will see "HF" in the Diagnostic tab, not "HL".
Remember, when you are testing banks, you have to close the software. If software is running, active bank is selected there.
What version do you use? 2.0?
Yes I'm using 2.0 Iam unplugged and at low throttle neg pitch and hit resq swash levels and gives pos pitch. at 3/4 throttle about =7 pitch, hit resq swash levels and gives only about +4 pitch, I have resq slider at 80 percent. thks.
Do I have to set pitch for each bank or are they all Okay?
The software's Bank comparison feature is your friend...
velocity90
Hi,Coco66 wrote:The software's Bank comparison feature is your friend...
Where can I find this?
Verstuurd vanaf mijn HIGHWAY SIGNS met Tapatalk
-TT E700 V2-Spirit Pro-mks950-980-Kontronik Kosmik 160 HV -Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+ Spirit Pro
In the software it's on the Backup tab (the button is only viaible when Banks are enabled).
In the App is Menu / Banks / Comparison (never actually tried it there).
If you need 9° for flying then 7° on rescue would be to low, but I think 7° should be more than necessary to hover, but when trying 3D it could need more than that to save the helicopter, because you have to compensate a downward motion.
This parameter you have find out in flight.
regards Wolfgang
My Helis: Walkera 4G6 2S µBrain, Align T-Rex 250 FBL Microbeast, Oxy 3 Spirit Pro controlled by Jeti DS16
