DX9 set up no sats no gov
bill rob
Has anyone set up with DX9 no sats no gov,I could do with some help!
jgiannakas
Yeap I'm running a DX9 with an AR7700 using SRXL connection on my Goblin. To be honest there is no difference to a sat setup that I'm running on my 450L.
Shoot your question!!
bill rob
Thanks for your reply and offer to help,,Im quite new to DX9 and that's where my problems are,,I just want to set up so I can use rescue on the trainer switch,,so I need DX9 settings to enable this.I take it with pwm wiring there is no need for banks?,,,what should my tx gyro settings be?
again thanks for your help
Bill
jgiannakas
Did you follow my guide here?
Spirit Setup Guide
http://www.helifreak.com/showthread.php?t=643997
jgiannakas
I would strongly advise using he bind switch. You'll need to move the switch around to the trainer switch but it works MUCH better. It really needs to be a momentary switch that you'll use
bill rob
I will move the switch,I followed the set up guide,but its for governor is it not,with bank switching.
There is no set up guide for DX9 using pwm wiring,they are all for use of gov.
If you could tell me settings for DX9 that would help,also with pwm do I still need banks?
jgiannakas
Nope it's not related to governor
http://www.helifreak.com/showpost.php?p ... stcount=16
PWM connection or sats or SRXL has nothing to do with the setup on the DX9.
bill rob
jgiannakas wrote:Nope it's not related to governor
Great!, I`ll go through that set up then move the switch.
Thanks for your help.
jgiannakas
No worries. To avoid any confusion all your gyro gain values need to be positive
In the latest firmware I did not need to adjust end points to get my gyro to match the diagnostics screen. But I do recommend following the step on the guide
Mixes are used to enable rescue:
I've also added a voice command on switch activation
This is what the monitor shows before I click rescue
And when I push the button
bill rob
All good thanks to your good self,rescue working,I`m sure ive seen a video on you tube of moving the switch.
Thanks again for your help.
Bill
