Ive decided to change from PWM set up to just the spirit with satellite.Do I just need the first mix?,,,,I only want rescue.
Also in the diag tab my ele only goes to 50% both directions?,,if I increase travel adjust up to 150 I can get it to 75% each direction,any idea how I can get it to 100%? Do I have to use a governor with satellite set up?
Thanks in advance
Help!,,sattelite question and ele travel question
I have got DX9 and sat. Almost no adjustments on servo travel, required all arround 125 +/-2 points
I suggest setting up new model in transmitter and start over with spirit setup wizzard.
Might also try to save and reboot spirit after RX change, I do also suggest to use two sats if possible.
Yes, I guess that you have some old settings in your transmitter - with new profile it should be better to start.
