Hello
I'm a big fan of the Spirit System and i have converted already several birds.
Now i run into a problem:
The Setup is the following, jeti transmitter:
Jeti RSAT2 (EX-BUS)-> Jeti Centralbox200 -> (EX-BUS) -> Spirit Pro (2.01)
When i connect the Spirit to EXT1 (EX-BUS) connector on the centralbox i see both devices (Centralbox200 and Spirit) in the transmitters device-explorer. But i'm not able to enter/select the Spirit or the Centralbox. I got the message, that the device is not online.
When i connect the Spirit to EXT2 or EXT3 (EX-BUS) connector on the centralbox i can enter/select the Spirit pro, but not the Centralbox. I see both devices, but i'm only able to select and enter to the Spirit.
When i unplug the Spirit pro, i can always enter and configure the Centralbox.
Sacha
Spirit and Jeti Centralbox 200
unfortunately we can't respond to this question appropriately.
You should ask Jeti support to clarify this.
In any case I will try to get this information from Jeti too.
I believe that centralbox is missing required data for Spirit (it needs e.g. Spirit BIN file).
May I ask you a question Sacha? I am a little curious.
Where do you use this combination of CB200 and Spirit? On a Plane?
Sorry for being OT, but I am really looking forward to have a Spirit in my Krill Extra 330SC.
Ingbert
Ingbert
We are investigating the issue with Jeti. It looks like there is some issue with CB200 so that it can't handle EX Bus connection well.
