This is my 1st Spirit. All my other helis have BD3SX (Trex600 PRO DFC, Goblin500, Hirobo SDX Nitro).
I placed the Spirit (not Pro) on my newly built Trex700 DFC Gasser and I tried to maiden the bird this morning. Unfortunately, I wasn't able to get off the ground because it wanted to tip over every time it was getting light on the skids. There was no apparent vibration that i can consider mechanical.
I tried to reinitialize the unit 3 times and not tilting the heli after initialization but had the same result. All swash movement and rudder movements were ok.
I can see that the swash was correcting when I lift and tilt the heli on all axis (it was just a very small movement though).
Spirit (2.0) settings are mostly default for the trex700 except for the CCPM120 (it is reversed). Gain is at 60% and when I hit rescue, it gives positive pitch on the bench. On the diagnostic tab: All is working as it should be. I checked the log and it said: ""Good Health Message".
I have a DX8 and nothing is reversed except for Gyro. If it is not reversed, its giving me negative values and it is always in Rescue mode. So I reversed it and it is giving the right values. Even the diagnostic page in the spirit software is giving the correct values . In the monitor screen of the DX8, it gives me -60 on gyro when i hit rescue which is on a momentary switch.
Power for servos and spirit is coming from a BEC with its own lipo battery. BEC Tester gave a good result as well.
Any suggestions on what I am missing.
