Less settings in the tx please
velocity90
I love my spirits, I really do but why all the settings in the tx in stead of banks:
-Tailgain, please in the future an option to set staticly in the Spirit and still be able to use rescue.
-cyclic and tail rotation speeds fine tuning by dual rates again in the tx, please give us a decimal so 11.4 or 11.6 so we can fine tune it precisely to our sim rates without again using the transmitter.
-expo please in the Spirit, and true round expo, ail and ele expo in the tx is not meant for helicopter use which uses a lot of round movement. Tx expo is not round.
I like a clean transmitter and its much more logical and easy to have everything in a bank per headspeed. Also its much easier to change equiptment or share settings.
-TT E700 V2-Spirit Pro-mks950-980-Kontronik Kosmik 160 HV -Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+ Spirit Pro
kramrle
Hi Velocity,
You mean having a dedicated channel for setting head and tail rotation -> to tune them via a knob from the transmitter?
Then to see a percent value for the current tail gain - as given by the transmitter, to later set it permanent in the spirit?
And use a dedicated channel for rescue activation?
Since i use bank switching - an additional bank would be nice though - i don't use expo anymore on my transmitter.
Everything is set directly in the Spirit.
Cheers M
velocity90
No, gains staticly in the Spirit, not set by transmitter
TomasN
What is round expo?
velocity90
Ok, set 15 %expo on ail and ele, now in the middle what is the expo? Yes exactly, its weird, messing up your perfectly round stirred piroflip.
So for example at 9 o clock you have 15 procent expo (ail) and at 12 o clock you have 15 procent(ele) , but at 10 and 11 its less thus no perfect circle.
elfew
You are not right
DX9 - Chase 360 - Spirit
velocity90
Im very right, check the spartan explanation my friend
velocity90
elfew wrote:You are not right
Post 30 and 34 for you, and please do research before saying someone is wrong :
http://helifreak.com/showthread.php?t=6 ... xpo&page=2
TomasN
Thanks, I understand what you mean
