Hobbywing v4 60a log full of rpm sensor noisy
mattbeau
Well maybe not KST in general, maybe just one of mine. I have a mix of version 1 and version 2 KST's
I wish there was an in line filter we could possibly use to guarantee that governor signal was clean, everything else is perfect.
Sent from my SM-T710 using Tapatalk
mattbeau
Bench testing with the H3050s shows no rpm sensor noisy logs. I'm still waiting for parts to repair mine to truelly test it
Sent from my SM-G930V using Tapatalk
Adrian
If a servos is causing noise, might try to put ferrit on servo lead to filter noise source and find cause this way.
I do allways pug a low esr cap on free FBL Servo port or with Y cable on any servo to fillter noise on bec power close to servos.
Rpm Filter of 2 means allmost no filter, higher number means more filter.
velocity90
A problem has been found with at least the v4 60a version.
-TT E700 V2-Spirit Pro-mks950-980-Kontronik Kosmik 160 HV -Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+ Spirit Pro
mattbeau
Im using the hobbywing phase sensor.
mattbeau
Adrian wrote:If a servos is causing noise, might try to put ferrit on servo lead to filter noise source and find cause this way.
Im using all the ports. Where would you recommend a cap?
Ive never used caps before what V and uF?
Adrian
I use 10V 2200uF low ERS Typ Capacitor like UPW1A222MHD:
http://eu.mouser.com/ProductDetail/Nich ... 1CXaltM%3d
If you can solder yourself, just take old Servocable and solder black to - and red to +.
Plug it to free port or use Y Cable on any TS Servo and plug Capacitor to it as well.
http://www.freakware.de/shop/abilder/spm1600.jpg
I guess any RC Store have such protectors, like HK sells them as well.
http://www.hobbyking.com/hobbyking/stor ... URN-VP.jpg
mattbeau
Great. Thank you. Ill get one ordered up.
This is going to be one advanced oxy 3[WINKING FACE]
mattbeau
So i flew my oxy with the h3050s and still have dirty rpm signal. I'm going to try the capacitor next. If that doesn't work, I'm giving up
velocity90
The problem is in the hobbywing v4, it's confirmed.
