3 blades rotor heads
JamesO
Can you tell me if the Spirit controller supports multi-blade rotor head? If yes, how do I change the swashplate timing.
thanks
Gtamas
Yes it does.
In the pc software, advanced tab, expert settings, and there is the "cyclic phase" what you are looking for.
JamesO
thanks, I am new to the multi-blade rotor system, can you tell me what is the proper phase to set a three blade rotor?
thanks
Gtamas
Depends on the rotor head. Mostly 3 blade systems uses the sam 90 degree as the 2 blades systems, so you dont have to do anything with this setting. What head exactly are you talking about?
JamesO
Gaui X7 three blades.. thanks
MarkusD
You Need to adjust it until the blade which is over the boom does not move when using cyclic forward- this value may vary as mentioned depending on head geometry
BR,
Markus
Gtamas
I think gaui x7 3 blade aldo uses 90 phasing so you dont need to do any specific with it.
MarkusD
Gtamas wrote:I think gaui x7 3 blade aldo uses 90 phasing so you dont need to do any specific with it.
Could well be the case....but i would always check as i said....don't think that anybody wants to fly with strange settings
