[SOLVED] Taranis integration
leatherface
Hi.I recieved my integration cables this week and downloaded the lua scripts.I have it all working but on the channels screen all channels are initially visible but then disappear when the screen loads leaving only the throttle,gyro and bank channels visible.is this normal?also I noticed in bank 0 govenor wasnt activated so tick the govenor box and clicked save,but it wont save.other things will save but not govenor.are there still some bugs to.sort out with this?also is it possible that rpm meter will be included in the future.I was looking forward to using this with integration but its not included in the govenor section.would be nice to see rpm readout directly on the taranis screen.
Hi!
Yes, in the channels it is perfectly normal. While settings are not loaded yet, you can see additional channels. But for the integration we have decided that it can be better to show just these that pilots are changing, to make it more clear. Basic channels are not visible, because with Taranis you can assign anything directly in the OpenTX. Also if you can use our supplied EEPE profile you have already it allright.
http://spirit-system.com/dl/opentx/Spir ... rofile.zip
Regarding Governor we will verify it.
Absolutely, with upcoming updates there will be new features, including RPM data via telemetry.
There are many possibilities.
leatherface
Awesome.thankyou for the response.very happy with my spirits and the open tx integration is the icing on the cake.keep up the awesome work.
Thank you!
Please download updated script with the fix for your governor issue.
http://spirit-system.com/dl/opentx/Spirit.zip
Now it should be OK.
leatherface
Great.thankyou very much.
leatherface
Hi.I hadnt played with the taranis integration to much until today.on bank 0 it wont save govenor settings.govenor response and holding performance are always on 10 and 1.if I change these and click save then go out and back in to integration they will be 10 and 1 again.could you please check this.thanks.
please download the latest PDF guide and script files.
Links are in the PDF. The linked scripts are unfortunately outdated now.
http://store.spirit-system.com/cs/index ... achment=12
leatherface
Hi.im pretty sure I have latest scripts etc,but still having this problem.if I want to change govenor settings I have to do it through wifi module.if I change govenor settings via taranis integration they will not save,they always revert back to 10 and 1(response and holding.performance).I make sure I click save,but no good.is there something im doing wrong?
leatherface
Ok, I think problem is solved.I had the real time tuning feature set up on rotary dials for govenor response and holding performance.I unassigned them in spirit software and now it will save value on taranis screen.
Ah, this could be good explanation.
When the integration menu is on, Real-Time tuning is inactive. But when it is turned off a new value can show up.
Then it can be also saved.
Thank you for the update!
