Unit fried?
trigen
Was working on my chase with spirit pro and plugging in an unplugging the battery a few times (esc to aux 1 no power, rx pack connected to aux2) and the unit seems completely dead, firmware recovery does not work either. Guess that's it, must have shorted in some way?
Hello Trigen,
Can you tell me if something was connected to the SYS port or Satellite ports at this time?
Can you tell me what was the wiring? Or you can take a photo - how the connectors were connected.
We are testing each unit carefully before the shipping, so I hope that it was OK.
Maybe the problem is in some connection.
Fortunately I am sure that we can fix it and check what is the problem and how it happened.
We can repair any damage in one day including shipping. If you can send the unit to us, it will be very quickly with you again.
Where are you from?
trigen
Thanks for the quick reply, i live in Norway.
Nothing was connected to the sys port but I had 1 dsmx sat in. I took a picture of the connections as it were at the time.
I normally use a hobbywing internal bec but an rx for testing a scorpion esc this time
I also have another spirit pro which works fine with the same power input
The connection is looking good.
Do you think you can ship the unit to us?
Or if you have bought the unit from Norway dealer, you can send it to them.
If you can ship it directly to us (in a bubble wrap) it will be perfect.
trigen
Ill ship it directly so you'll have it as fast as possible.
Mind giving me the address?
Thank you. That will be perfect!
You can find the address on the white Spirit box or here:
http://store.spirit-system.com/en/content/4-about-us
