[SOLVED] Spektrum AR8010T / AR9030T
warhog
has anyone tried to use SRXL with the new Spektrum AR8010T / AR9030T receivers?
Seems like they changed the checksum generation again, at least it is not working
with the Microbeast (also with the Spektrum special firmware). From what i read it
is also different from the AR7700 SRXL format.
I can't answer the question right now.
But for sure we will add the support if it will not work.
We have implemented more algorithms for this protocol so it is possible it will just work.
warhog
okay, i'll just ordered an AR8010T. Should be in stock during next week.
I will keep you updated when it arrived.
great. Thank you very much!
warhog
My AR8010T arrived today, everything is working using SRXL :) awesome
Keep up the good work!
