Hello Tomas!
Today got the WIFI link!
But unfortunately I have a problem?
Please write me what I need to do?
LG Gernot
Wifi Link
please wait for a few days, until we will release new Android app. This problem is caused because you are registered as a testing pilot and using a testing firmware.
But in a few days it will be there. Alternatively you can just downgrade the firmware in the unit to the official.
We will release new version for Wifi-Link very soon (maybe today) so you will be able to use Web interface to access the Spirit Settings.
Later Android app will work too.
The only issue could be caused by selected encryption in your home network.
Do you know which one it is?
Also make sure that password is entered correctly, it is case sensitive.
So far, any cell phone or laptop could enter the password into my network without problems!
But the Wifi link is not seen in the network. It is switched on and flashes blue. I have the Wifilink software started and then comes the message "Could not be found"
And over the Brouser he can not find 192.168.4.1 also!
What am I doing wrong?
Greetings Gernot
Ah, it depends which way you want to connect to the Wifi-Link.
Normally people are just connecting to the Wifi-Link network (which should be detected immediately after first power up) and then connect there by smartphone.
Is this working?
The module is behaving as the Access Point.
There are other ways how to make connection with the module, but this is the easiest.
Is this working?
Hello Tomas!
With the Smartphone it folds, after downgrade impeccably!
But with the network at home not, it is not recognized?
When will the new Android app come? And how do I recognize that it is new, I see in the app no version number?
Greetings Gernot
Great.
When you are connecting to your Home network, do not forget to change the module mode to AP+Client.
Then you can do a scan of the wifi networks.
And then you should be able to find your home network, put there password and thats all.
Do you know if your home network has DHCP?
How you can recognize the version? You will not see this error. Right now you can see the version in the Connection tab - Software: 1.0.X
