[SOLVED] Gyro heading hold direction reversed
LouE
I am new to the Spirit Pro gyro and completed the initial set up . The spirit Pro gyro heading hold correction is reversed in my set up . I have tried every thing I know but cannot seem to correct it.
No place in the manual or the in the computer set up of the Spirit PRo can I find a way to correct or reverse it. Page 68 sec. 6.1 step number 4 says to check it in the manual ,but does not tell how to correct it.
Every thing else in my set up works correctly .
Hello!
Welcome in the forum. What you wish to do is very simple. During the Setup wizard it was only needed to tick the CH4 in the Servos page (Step 6). This will reverse the rudder servo operation. You can see full explanation for this problem in the Step 6.
If the Wizard was finished but you have missed it, you can do it now in the Servos tab - Servo reverse.
LouE
solved the problem. Thanks
Thank you for the info.
You are welcome.
