New Logo 700 Set Up
gabs_mex
What will be a good starting point for the new Mikado Logo 700
Logo 700 Set Up
Motor: Scorpion 4525-520
ESC: Scorpion Tribunis 200
BEC/RX Pack: Internal BEC
Servos: BK DS-7002 Cyclic & BK DS-7006 Tail
FBL System: Spirit Pro / EX.Bus Jeti
Rotor Blades: VTX 717
Batteries: Pulse 12s Stick 5000 mAh 45c / 2x6s Revolectrix Platinum 5200 mAh 40c
Extra Notes
Gearing: 14T/136T
Headspeeds: 1800, 2000, 2150
Very nice setup!
If I can suggest, get a different servo brand (but this is only my personal suggestion).
For your setup nothing special is needed. You can just select Logo 600 or 800 preset and then it should work fine.
Pirouette consistency will be somewhere around 175 or more.
For your servo parameters you can check this table:
http://manual.spirit-system.com/index.p ... Servo_list
gabs_mex
way the servo suggestion?
what are the problems that you know.
I recommend MKS, alternatively Savox and Align will work well.
I do not wish to talk about any product in regards of pros or cons (or possible failures).
I want to avoid that you will suffer from issues that other users interfaced with these servos. I can tell you more details in private message if you are interested.
But normally these servos working very well too. So if you have already bought them, it will work very likely good.
gabs_mex
Hello, i will like to know more, can you send me a PM.
Best Regards.
