Problem with Tail
Sheep78
I tried Delay with 5, Not better. how much i should increase?
TomasN
http://manual.spirit-system.com/index.p ... t#Graupner says delay 0-3 for HBS770 with speed 0.045s/60dg. @ 7.4V. Yours is 0.068s/60dg. @ 7.4V.
So if there is direct proportion (servo construction is same) then 5 looks good. Did you set gyro gain to maximal value without oscillation?
Sheep78
Yes, the max gain in fast curves is set.
What you can do is to set Revomix to 1-3 now (but not more).
It is possible that for such collective pitch tail mechanics is not efficient enough - else you will need to increase Head Speed.
Sheep78
I increased the Rudder Endpoints and set the Revomix to 2. Now my Tail nearly perfect.
Many thanks for Support.
Lars
Great, thank you for the message!
If I can help you anymore, please let me know.
