hirobo lama
keeny
Hi can i use this unit on a hirobo lama ?
Cheers Chris.
alchemy66
keeny wrote:Hi can i use this unit on a hirobo lama ?
Cheers Chris.
Of course, why not?
keeny
ok next dumb question, which type swash do i select it not the usual ccpm
alchemy66
keeny wrote:ok next dumb question, which type swash do i select it not the usual ccpm
Swash 1 servo, no mixing at all, spirit does that. What tx? You need to give more detail. ☺
keeny
I've set up spirits on 5 of my helis I'm just not familiar with what type of swash to use in the spirit software for the lama
It should be configured for CCPM 90.
You will see if the swashplate is moving correctly, but definitively it must be 90° aligned.
keeny
Ok, I'll try that thanks for the info.
keeny
ok, guys how does the spirit use ccpm 90 on the hirobo Lama when the lama doesn't use ccpm.........im confused big time.
I have it set up using ccpm 90 but elevator does not compensate when you move heli on the bench.
Please verify that there is no special mode activated, since it should work with CCPM 90° well. If there is e.g. Subtrim (tuning) enabled it will do nothing when moving with the model.
When you will move with model in the aileron axis, it must control the aileron servo. When you are moving in the elevator axis, your elevator servo must be moving.
Pitch is controlled only by your transmitter so movement has no influance there.
Maybe your elevator servo is connected in the Pitch output?
keeny
Ok thanks for the replies, i will go over it all and double check everything. Looks like i have managed to have 2 threads going on the same topic.
