oscillates on Tail, Logo500
Bjoern_ve
HI.
After an update from the 1.xx to the current firmware, I have my LOGO 500 problems with the rear. It oscillates at a speed of approx. 1500rpm. At higher speeds I could not determine.
Is there an explanation?
Setup:
Kontronik Jive100LV
Swashplate: 3x Savöx 1257TG
Tail: Savöx 1290mg
Motor: Scorpion 4020 1100KV
Björn
Gaui X3, Gaui X7
there are big difference between 1.x and 2.x firmwares. So it will require also slightly different setup. Especially regarding the Gyro Gain, Rudder Delay and Pirouette Consistency. Also Subtrims are different.
So if you are using same values, it might be needed to update them.
You can send me your settings so I can check it.
Bjoern_ve
here are my settings files.
Björn
Spirit LOGO500_B2.4ds
(255 Bytes) Downloaded 109 times
Spirit LOGO500_B1.4ds
(255 Bytes) Downloaded 105 times
Spirit LOGO500_B0.4ds
(255 Bytes) Downloaded 104 times
Gaui X3, Gaui X7
