Governor and SRXL
George Baker
I'm installing a new Spektrum AR9030T receiver and connecting it to the Spirit (not pro) with an SRXL connection. Will the SRXL connection pass the RPM telemetry signal from the receiver to the Spirit so the Spirit governor can be used or does the RPM sensor have to be connected directly to the Spirit to use the Spirit governor?
I'm thinking that would be too good to be true but it doesn't hurt to ask. Thanks
when the RPM sensor is not present, RPM data are displayed from the ESC. So it support both.
George Baker
Thanks,
I have a magnetic RPM sensor connected to the receiver. Gas engine servo for throttle. Any way to pass RPM signal from the RX to Spirit in order to use Spirit governor?
jgiannakas
Just splice the wire and plug it in both.
George Baker
Question;
"Any way to pass RPM signal from the RX to Spirit in order to use Spirit governor?"
X-Bus? SRXL?
You can do so always by a RPM sensor, so it is not entirely dependent on the used protocol.
Unfortunately it is not possible to pass a RPM signal from your receiver to the unit.
George Baker
OK, Thank you.
