Servos are Spektrum H3050 set at 1520 us and 200 hz as per the servo list.
Went through the setup again with my Soko. The servos centered, have 0 degree pitch, the swash is level but everytime I active the 6 degree setting it comes out different by a couple degrees not sure which setting to trust.
Will try hover again tomorrow morning and see if it's any better. Earlier today hover was very unstable in Norrmal Stabi with stick priority at 0.
Tail Motor
lostmyheli
OK Tomas tail and stability issues are fixed, all do to operator error.
Gyro channel in radio was reversed so in Stabi mode I was sending pos gain and in normal
mode sending Neg gain. DUH !!!!
George Baker
Very glad to hear you got it sorted! How does the model feel now with the new gyro vs the original one?
