I cannot operate telemetry from a kontronil jive pro with a futaba t14 SG and spirits units ( red and pro).
Futaba firmware 7 is installed on the T14, spirit unit are flashed with firmware 2.4.3, telemetry is set on kosmik and jive pro in advanced menu of the units, and kontronik ESC are flashed with 1.9 firmware. The RX is a 7008 SB, and set on fasstest 14 CH single and global. Telemetry is activated (0.5 sec).
In the TX, sensors are set to roxxy on slots 1 to 5 and then slots 6 and 7 are set to SBS-01V.
For the wiring, here is a photo (BE CAREFUL, THIS WIRING IS WRONG):
The connector on the left is the kontronik telemetry cable , must be connected to sys port (orange on signal pin)
The connector on the middle is the light brown wire from kontronik, (must be connected to elev pin) and the orange wire from frsky telemetry cable (must be connected to ail pin).
The connector on the right is the frsky cable ,( red wire must be connected to signal pin on the rudd port.)
For the frsky cable I took attention: the shorter head of the cable is well conneted to sbus2 port on the receiver. Of course, the little connector of the kontronik telemetry wire is connected to kontronik jive pro data port.
So with the red spirit, it sets well, but I have no data from the kontronik esc on my tx screen, only the internal receiver voltage. (This shows that the futaba telemetry works.)
And the spirit pro do not want to initialise with the same wiring and settings.
I surely made a mistake somewhere, but I do not know where ?
( sorry: it is not easy to explain in english for me !)
