µSpirit and SPM4649T
PeteMarr
Has anyone tried to link the µSpirit and SPM4649T? If so, can you share how you wired it.
Coco66
Well, it's depending if you want to use the integration or not...
For a normal connection, I used Red and Black to RUD (for power) and Blue to SAT (for signal). From the longer Receiver cable, the one with the male plug.
For integration you need the same for power, and the signal to the Ail pin, and use the shorter Receiver cable, the one with the female plug (called Bind/Prog in the Receiver manual).
For the second you will need FW 2.4.3 and some additional configuration as per the guide.
PeteMarr
Thanks,
That worked perfectly. :)
